Zum Hauptinhalt wechseln
vertical lines on my display
Hi All,
I have a couple of vertical lines on my display - the number of lines are growing slowly(6 at the moment)
I mirrored the display on my TV , no lines there.
Is it the display panel itself or could be the wire connects the logic board to the LCD?
Or something else?
Thanks.
Update
I did lot a research on the web, and figured there are lots of people who suffered from the same issue.
There are two possible solutions:
1. You buy LCD panel online and take it to a pc shop and pay for repair.
2. Make a lots of phonecalls to apple and if you pushy enough might get lucky and apple might fix it for you for 30-50$. They changed mine LCD. Said there was a factory defect on some of the LCDs for the G5s.
Give it a try! Good luck
Update 2
Here's a useful thread to check.
Ist dies eine gute Frage?
Bewertung 4
4 Kommentare
Adrian
I had open mine before they fixed it, i had lg/philips lcd panel in mine. I think the brand does not mater if it fits, have the required connectors and matches the resolution
You can check the following links:
these are pricey a bit:
http://mac.macrecycling.com/displayscree...
http://www.welovemacs.com/6613626.html
this is the cheapest one:
http://www.dvwarehouse.com/Apple-LCD-Dis...
Hope that helps..
Tamas
von
Great, can you tell us under what repair program or recall that Apple did this so that your answer could help others?
von
Nice updates on your question Tamas! I actually have this problem on an old Alienware right now. I'm hoping it's just the display data cable, but I'll open it someday soon.
von
Thank you
lines are multicolours and they are fix at the beginning and then start changing colour so it looks as they are moving but the position is always the same in the right-middle. I have a new LDC from Apple becouse I alredy had a pixel break down, I still don't understand exactly what's going on
von
Einen Kommentar hinzufügen
6 Antworten
Hilfreichste Antwort
Are the lines in fixed positions on the screen - i.e. if you change the display resolution in System Preferences/Displays - are they still in the same place?
if they stay in same place and also no corresponding lines appear on an external display, then it's likely the LCD panel itself (and not the graphics chip)
there are a couple other posts with the tag lines on screen where I previously mentioned possible failure of LCD driver ICs
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks for the quick response bac!
The lines are in fixed positions on the screen - yes, if I change the display resolution - they are still in the same place.
I will take it appart and try to pressure the connectors gently.
What do you think could it be the display data cable?
Or no chance, i have to replace the whole panel?
Thanks again.
von
The 17" and 20" screens in both the iMac G5 Isights and the first gen intel iMacs are notorious for having bad lcd Panels - Usually shows up as blue or yellow vertical lines Approx 1px wide.
Bewertung 2
2 Kommentare:
Right now i have two 2-3 pixel wide white vertical lines.
And four 1 pixel wide purple yellow and green lines. Two of these are different colors (changing) from top to bottom.
von
Is there a solution for the vertical lines on the 17" isight G5? I.E. Is there a source for this LCD panel. Is it possible to replace the screen with the always increasing number of lines with a working one from the original 17"iMac G5 or will the connecting cable not fit? I have been salvaging the original iMac G5's because of defective power supplies and bad caps on the mother board, but the screens still seem OK.
von
i got mine fixed by apple for free. Its a special kind of thing for our type of iMac's. Its more like a Customer Satisfaction thing.
Bewertung 1
I had the line 1 appearing, then line 2, and line 3 it took several months before it became unbearable, after several calls and personal questions to Apple, and different answers, I finally payed Apple 35 Euros, instead of 500, and had the problem solved.
This is only, I think, with iMac G5 17" with built in camera.
Bewertung 0
2 Kommentare:
Great. What was the solution?
von
vertical lines appearing and dissapearing after "warming up" on screen, I must check but it could be a little oxidation of logic cable
Robin
von
The underneath video has 8 parts, you have to search for it to see the whole process... it seems to be the cheapest and most durable fix ;)
As to the root of the Problem:
I did some research myself and found that most display problems are in fact gpu, or better gpu solder problems. The GPU is only cooled by a heat sink, apple's official idea was, that the cpu cooler would pull the hot air also off the heatsink, what doesn't work at all. Just hold your hand left above the apple sign after you used it for a while and you'll see what I mean. Because this heat, the logic board deforms very minimal but enough to brake the soldering... you see very similar problems in notebooks and game consoles.
So if you're at a point where you would through away your iMac anyway, you'd might give this a try and maybe end up with a useable computer again ;)
Part1:
http://www.youtube.com/watch?v=Ok2uJZSQD...
Part6:
http://www.youtube.com/watch?v=nqAg4c9Sf...
Bewertung 0
I had mine changer by Apple for free even with no warranty, after lots of calls in the past two years
Bewertung 0
Antwort hinzufügen
Tamas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 31,651
