Zum Hauptinhalt wechseln
Der Game Boy kam am 21. April 1989 in Japan auf den Markt, dann am 31. Juli 1989 in Nordamerika und schließlich am 28. September 1990 in Europa. Er ist erkennbar an einem großen grauen Gehäuse und der Modellnummer DMG-01
64 Fragen Alle anzeigen
Is there anyway to reapair this gameboy?
I found my dad’s old Gameboy.
He told me that he left it with a cartridge and batteries, around 20 years ago. I decided to check if it would work, but I saw the corrosion and decided to check inside. Well it looks like this
Didn´t look good. But then I saw the other side.
I’m pretty much sure that this thing is cooked, and the only way to work is to get a new motherboard. But I still wanted to get a second opinion. Is there any way to fix this?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hard to say but it is worth trying. Remove the logic board and brush with Isopropyl alcohol. This should remove all the corrosion on the top layers. If you did not attempt to power it on and the corrosion hasn’t corroded the traces on the other layers of the logic board there will be a good chance it might work.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
roroanama wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 45
