Zum Hauptinhalt wechseln
2,2 GHz (Turbo Boost bis zu 3,4 GHz) oder 2,5 GHz (Turbo Boost bis zu 3,7 GHz) Quad Core Intel Core i7 Prozessor mit 6MB geteiltem L3 Cache.
467 Fragen Alle anzeigen
MacBook Pro display not working after repair. What could cause be?
Yesterday I did a self repair on my 2015 MacBook Pro retina, following the instructions here MacBook Pro 15" Retina Display Mitte 2014 MagSafe DC-In Board austauschen
When I reassembled everything and powered on, my MacBook screen remained black. I plugged into an external monitor, to confirm that everything but the display seems to be working.
I double checked the display data cable, confirming that everything was connected, and that the pins weren’t damaged. Things looked good
What else could be happening?
Possibly relevant detail:
The only slightly suspicious thing that happened when I was re assembling was that as I was putting the logic board in and aligning all the ports, there was a small click sound. I’m prettty sure it was the board/ports clicking into place, but I suppose there’s some chance it could have been something cracking.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Clearly something popped! Did you leave a screw under the logic board or put the wrong screw in as there is one place a short screw is needed. Review Step 30 in the guide you used.
War diese Antwort hilfreich?
Bewertung 1
16 Kommentare:
Oooh, what do you mean “popped”? I don’t think I left something under the logic board, as I wasn’t missing any screws at the end. There’s a good chance I mixed up some screws at some point, in particular step 30 and 19. (I actually didn’t think it mattered too much! though I was pretty careful for the most part).
von
I did try one re-arrangement of some of the screws from those two steps, and that didn't quite fix things. Did you mean there is one place where a _long_ screw is needed, or a short screw?
von
@jonathandubin - There is one location that mush have the shorter screw, its marked in the guide.
von
Hey @danj, I’m taking a look at the guide. Do you mean the orange / 2.5mm? It seems to be the shortest screw in that group/bunch.
Pic linked here https://www.dropbox.com/s/7ud3ury4n73k86...
von
@jonathandubin - Yes that's the Step with the details. Sadly, once you install the screw it messes up things.
von
11 weitere Kommentare anzeigen
Antwort hinzufügen
jonathandubin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 50
