Zum Hauptinhalt wechseln
Repair your Dyson V6 Animal vacuum with a part replacement guide.
Non of the brushbars are spinning
I have an old dyson v6 it’s no blockages all connections have been cleaned no hair in any heads and the battery is fully charged and has suction but won’t work on any of the Motörhead’s. Any ideas I’m stumped.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Merry Christmas Gillian,
There are only two possible reasons you're having this problem. Mechanical, in that the power brushes are broken, or not enough suction. If you can rotate the power brushes easily by hand and as you said there is no hair or other debris clogging the mechanism, then the problem must be lack of suction. The filter at the top of the motor head could be the problem. Take it out and soak it overnight in water. In the morning shake it underwater vigorously. You might be surprised at how dirty the water gets. I used to clean mine regularly by rinsing it under the tap, drying it and replacing it. I found out that is not enough. Good luck
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Gillian wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 287
