iPhone X slightly bent, Solder two layers together
How do I solder two layers back together when the top layer is slightly bent at the top?
Thanks in advance!
Ist dies eine gute Frage?
Thanks in advance!
If it is the front of the board that isn’t connecting I wouldn’t be too worried as they are all ground pads. If it is bent significantly you will need to solder the spacers back on and clamp it down while heating.
I think there are about 8 spacers. You might have to get them from an unseparated IC board if you haven’t saved any from the other boards.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 51
1 Kommentar
@iammyron07 two layers of what? Has the screen separated or the logic board? Give us more detail
von oldturkey03
