Why is coolant boiling out of the reservoir?
Coolant is boiling out of the coolant reservoir after the car warms up. However there is no white smoke out of the exhaust so I don’t think its a head gasket. There is a very small leak on the bottom radiator hose but its only like a drip every 2 minutes or so. I just installed this new radiator because the old one was cracked and I was hoping i would have no more problems. Does anyone know why this is happening?
Ist dies eine gute Frage?
3 Kommentare
Did you bleed the air out after replacing the radiator?
von Chris Stables
@imicrosoldering No, how do I do that?
von Maxwell
What model and year are you working with? Many have a bleeder screw you remove to bleed it. Do you know if your thermostat is opening? You can check this by seeing if lower radiator hose gets hot or stays cold when it blows over.
von Ed Hanson
