Zum Hauptinhalt wechseln
Das ist die LTE-Variante der fünften Generation des iPad, erschienen im März 2017. Erhältlich mit 32 und 128 GB Speicher, einem 9,7 Zoll Retina Display und einem 64 Bit A9 Prozessor.
How to bypass MDM after restore
Company I work for is moving offices and scrapping all our tech gear. Snagged an iPad but after restore its MDM locked. Need help bypassing. iPad 5th gen. Lte enabled.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
It’s implemented on the Apple activation servers, the server knows this ipad belongs to the company and has MDM enforced during activation.
You can always talk to the IT department to release it from MDM, or you can replace the major chips to swap identity of this ipad, probably costs as much as the ipad itself.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
@tomchai I have a2485 with the same MDM problem. Do you know who can offer service or what chip needs to be removed or reprogrammed? Thank you
von
@fobby New motherboard, or full chip swap. Contact the previous company to have it removed. Any competent company has a procedure in place when this happens, or the provider (like Absolute SW) has means to fix it.
Ideally, the best approach once the device is so absurdly old that there's little to no market left (like the D series, or old E series) is to just disable the crap permanently (but DISCLOSE THE PERMANENT BLOCK IN THE LISTING IF YOU SELL). I should be able to decide if I want to seal my device's MDM capability fate, even permanently, not the provider -- regardless of who makes it, even if I need to call Apple to tell them I want this thing blocked from accepting MDM until I SAY SO.
von
I found a way to get the MacBook open and bypass the MDM to turn the SIP off in terminal. I’m now wondering will it eventually get locked again and should I get some type of bypass now to prevent that?
von
Hilfreichste Antwort
I am sure the company will remove it for you if you ask. Besides that it is there for good.
Bewertung 2
2 Kommentare:
Not true. MDM is not permanent. Easily bypassed by a.bat file and other ways (file types) I am sure. Shouldn’t say stuff unless you’re sure, sorta like a lie. Smh
von
@aaronperea16224 Maybe at the time of posting the .bat file was not available. You should look at the date of posting. And maybe you should explain exactly how you bypass it.
von
The MDM can be bypassed on my 6th gen iPad (9.7). I used a .bat file I downloaded from a YouTube link. Just search for MDM bypass iPad rob. The content creators name is rob something, you won’t miss it. Promise. It’s all FREE AS WELL. TOOL USED is called 3utools, & I have used it for years now. No viruses or bs money asking bull. I swear. Your all welcome:)
Bewertung 0
1 Kommentar:
Until you restore it and then it comes back being tied to the S/N...
von
Antwort hinzufügen
mjblaich wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 17
Letzte 30 Tage: 92
Insgesamt: 1,967
