Zum Hauptinhalt wechseln
Die Wi-Fi Version des iPad Mini 2. Angekündigt am 22. Oktober und erschienen am 13. November 2013. Das iPad mini 2 bringt die Pixelanzahl des iPad Air auf nur 7,9 Zoll unter.
Draining the battery on an ipad mini A1432
So i’m doing this iPad mini screen repair. I’ve used the CPB Heating mat to lose the adhesive tape so i can pry it open. The heating mat works wonders, it opens with less mess. I always test after opening the damaged screen to see if the iPad still works. The device works but since that screen is cracked really really bad, the touch screen doesn’t work at all. My question is, how long that the battery will last since I want that thing completely dies so i can safely disconnect and reconnect the ribbon cables. Please assist, thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
I was able to do the work without any further issues, kudos for your assistance!
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It would be quicker and safer to disconnect the battery. You will have to remove the plate anyway to disconnect the screen flex, and the battery connector is right beside it.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Oh okay, I can still disconnect the battery regardless if the iPad is still on.
von
@uitadmin Yes it is perfectly safe to do so.
von
Antwort hinzufügen
Gabriel Rodriguez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 160
