Zum Hauptinhalt wechseln
Veröffentlicht im Juni 2009 / 2.66, 2.8 oder 3.06 GHz Core 2 Duo Prozessor
297 Fragen Alle anzeigen
2009 Airport Card with a 2011 display assembly? MBP 2009
Hello, i have a bit of a problem, I have a mid 2009 MacBook Pro 15 inch and i could only find a screen assembly from a 2011 MacBook pro which of course doesnt have an airport card inside with the same isight and sensor cable that the 2009 have,
would it be possible if i bought the 2009 airport card, connected it up with the logic board and left it free inside the case, to hook it up with only two out of the three antenna cables of the 2011 display? since the 2009 airport card only has two antenna connectors but the 2011 has three cables..
Thanks for any insight.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Frankenstein’ing is not really a good idea. The display frames are very different.
Here’s one source for the LCD panel LG LP154WP3-TLA3 15.4" 1440 X 900 Apple Macbook Pro LED Screen
War diese Antwort hilfreich?
Bewertung 1
5 Kommentare:
oh well, i already got the 2011 lcd which has the same lvds connector so the display it self should work, though airport, isight and etc wont
von
@Gaming York - If thats the case just swap out the LCD panel its a bit of work but that is the better direction at this point.
von
yeah thats my plan
von
@Gaming York - I hope it all works out! Don't forget to score the answer and accept it - Thanks!
von
just did, sorry it took so long
von
Antwort hinzufügen
Gaming York wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 26
