Zum Hauptinhalt wechseln
Authorized Homelite dealers nationwide, including lawn and garden and building supply stores, sold the blowers from October 1994 through December 1996 for about $200.
Why is no fuel getting in the cylinder an not starting
Is there any way any one has a manual for it
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare
Hello snsjss
von
@walker34 your blower a Homelite backpack blower (bp250)? If not we need more info about what engine it has etc.
von
Plugged gas line, fuel filter, fuel valve or carburetor gummed up.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
change the gas line and remove the carburetor. use carb cleaner and remove everything to pieces and blow the cleaner in every hole. the float bowl injector is the screw that holds the gas reservoir of the carb to the engine. this is usually the culprit and needs to be cleaned.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Ethan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 29
Letzte 30 Tage: 59
Insgesamt: 999
