Zum Hauptinhalt wechseln
Das größte und teuerste Smartphone, das Apple am 20. September 2019 angekündigt hat, verfügt über ein 6,5" OLED-Display, ein Kamerasystem mit drei Linsen und eine deutlich verbesserte Akkulaufzeit. Es ist der Nachfolger des iPhone XS Max.
20 Fragen Alle anzeigen
Will the LCD Screen Replacement Cause Board Damage?
Hello everyone, new here.
So, i have a completely destroyed iPhone 11 Pro Max that i would really like to fix up to avoid it becoming just more e-waste. Question is, i’ve done a bit of research on LCD displays retrofitted onto OLED iPhones and from what i see they usually cause board damage because of more power draw, but i wanted to find out if this magically happens to not be the case with the iFixit display.
Thanks a bunch for all the help!
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
The issue is on a OLED the backlight pulls more power to give bright displays. however not all backlight leds are created equally so this is something you may want to call ifixit about.
War diese Antwort hilfreich?
Bewertung 0
the power ic went off
Bewertung 0
2 Kommentare:
Bummer dude.
von
@adomchrisofori, is there a question in there? With just your statement we have no way of knowing what you're looking for by coming here. Are you saying your power IC died? How do you know that? What relationship does your question have with a post regarding using an LCD display on a phone originally designed for an OLED display?
von
Antwort hinzufügen
Tyler wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 251
