Zum Hauptinhalt wechseln
Erschienen am 4. November 2017. Modell A1865, A1901. Erhältlich als GSM oder CDMA / 64 oder 256 GB / Silber oder Space Grau. (Genauso ausgesprochen wie "iPhone 10")
1200 Fragen Alle anzeigen
iPhone X 0% Remaining
Hello, I have an iPhone X which had a battery replacement, and was working fine until it randomly restarted and the battery percentage now shows as 0%. The battery health also shows as service, but before the restart it showed as 100%. It also randomly restarts, does anyone know what the issue may be? Thank you
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Your battery have loose connection with battery connector or battery connector have been damaged while replacing battery…..so go and have ok on it
War diese Antwort hilfreich?
Bewertung 2
Hilfreichste Antwort
If you have ruled out the battery it will most likely be an IC2 SDA or SCL problem. Check readings on battery connector data pins. Check for nudged components Q3200 and Q3201. If all looks good replace U3300.
Bewertung 4
1 Kommentar:
Sometimes is battery and sometimes MOSFET can also cause it, because when is damaged it can result to 0%remaining. Check very well close to the battery terminal and change the MOSFET...
von
Sounds like you got a bad battery. Try another.
Bewertung 0
Antwort hinzufügen
Colby Morris wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 30
Letzte 30 Tage: 96
Insgesamt: 3,630
