Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
8 Kommentare:
Did you reboot? Also reboot wifi router at same time. Turn off phone than reboot wifi router
@stressmaster Unfortunately, I only can connect to routers that support 5ghz Wi-Fi. I can't send even a hotspot to any device until I change the hotspot band to 5ghz.
von stressmaster
I did. It doesn't work.
von Omar Attia
@Omar Attia can you connect to other 2.4ghz wifi? Also did you tell phone to forget the old wifi?
von stressmaster
von Omar Attia
It is possible the wire that is the 2.4Ghz in the phone came loose. Or the board has a chip or resistor/transistor burn out.
von stressmaster
3 weitere Kommentare anzeigen
