Zum Hauptinhalt wechseln
Mitte 2006 / Modellnummer A1181 / schwarzes oder weißes Gehäuse / 1,83 oder 2,0 GHz Intel Core Duo Prozessor.
will the later 2007-2008 lower case fit a 2006 core duo?
The battery hold down lock in my 2006 core duo is defective. I do have a few nonworking 2007-2008 Core2duos at hand with good lower cases. Are they interchangeable? Ifixit’s parts numbers are different, but maybe there’s a hack that will work?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
I am 100% sure it will work
War diese Antwort hilfreich?
Bewertung 1
Assuming you'll be porting over all of the other internal components (the heatsink, the fan, AirPort card, MagSafe board, battery connectors), etc, it should be possible to transfer your Core 2 Duo motherboard over. The main thing to be watchful for is that the screw standoff positions may be different in the Core 2 Duo A1181 bottom case. The easiest way I can think of is to look at the compare the final images of the bottom case for the iFixIt Lower Case replacement guide between the Core Duo and Core 2 Duo MacBooks...but even then you potentially won't know for certain without attempting the replacement.
If the screw positions do differ significantly, you may have to cut any conflicting screw bosses off of the bottom case (i.e. with a Dremel) to accomodate the motherboard.
Bewertung 1
Antwort hinzufügen
Bernie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 68
