Zum Hauptinhalt wechseln
24-Zoll-Display; Integrierte iSight-Kamera, Mikrofon und Lautsprecher; 1920x1200 Auflösung. Erschienen im Oktober 2008, identifizierbar durch die Modellnummer A1267.
waking it up from sleep the monitor did flicker
Hey folks!
It's almost 2022 and this monitor is till knocking around. I really is a nice display and design and would hate to throw it out. I tried Barkin Tunga's fix and tough it didn't solve the problem it did confirm that the monitor still has life in it.
Barkin Tunga's fix here: 24" LED Cinema Display flickers then dies (A1267)
Upon waking it up from sleep (connected to a 2013 MBP) the monitor did flicker and I could clearly see the desktop wallpaper on the display.
It seems to seems to me either something is loose, (cable?) or it could be a cold solder joint. Suggestions are welcome as to the real culprit.
Thanks folks!
~ EMJWAYLZ
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
To figure out the fault, you will need to disassemble the display until you can get access to the circuit boards in the machine. The videos Apple Cinema Display - Teardown and Repair and How To fix An Apple Cinema Display should help.
Take pictures of both sides of the circuit board and upload them here Bilder zu einer vorhandenen Frage hinzufügen
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Good answer +
von
Antwort hinzufügen
Michael J. Walls wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 256
