Zum Hauptinhalt wechseln
Die Smartwatch von Samsung wurde im August 2020 veröffentlicht und ist der direkte Nachfolger der Galaxy Watch von 2018.
Why do I not have sound anymore in my galaxy 3 watch
Why do i not have sound anymore?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
- Open Settings.
Phone: Navigate to and open the Galaxy Wearable app, and then tap Watch settings.
Watch: Navigate to and open Settings.
- Open the Hearing enhancement settings.
Scroll down on the watch or phone and tap Accessibility, then tap Hearing enhancements.
- Disable Mute all sounds.
If Mute all sounds is enabled, tap the switch next to Mute all sounds to turn it off. The switch will be in the left position when it is turned off.
- Open Sound and vibration settings.
On either the watch or the phone, navigate back to the watch's settings page, and then tap Sound and vibration or Sounds and vibration. Make sure the watch is not set to Mute.
- Check for water.
If your watch has been immersed in water, or if the microphone or speaker is wet, sound may not be heard clearly during a call. Dry the watch thoroughly with a clean, soft cloth. You may need to eject the water to restore the speaker to working order.
Contact Samsung for a repair.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
pam g wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 948
