Zum Hauptinhalt wechseln
Guides and repair information for external storage devices made by Synology.
Need component detail and circuit diagram for missing reset button
As per image - in a previous heavy handed RESET with an overlong paperclip, i have managed to break the reset switch from the motherboard.
I need some details of a suitable component and then the wiring / orientation for the four pins that will need soldering.
Alternatively, if someone knows how to temporarily short these four pins out then that would also be helpful, eg clockwise from top left 1 - 4, do I need to be jumping 1 to 3 or 3 to 4 or whatever.
Thanks,
Michael
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
That did the trick; many thanks :)
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @michaelfoggin ,
The yellow pins seem to be on the same Ground plane so I would try to short yellow with the pink circle, as per below.
What device is it? Do you have the model number?
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Hi,
it's a DS1817+
Thanks for speedy reply :)
von
Antwort hinzufügen
Michael Foggin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 795
