Zum Hauptinhalt wechseln
The Sony XBR-65X850D is a 65-inch LCD Ultra HD TV with an LED backlight and 2160p resolution. Released in 2016. Model number: XBR-65X850D.
Why is my TV screen dark upon startup, fine after warm up/resetting?
The TV in question is a sony xbr-65x850e.
About a year ago I noticed the screen is dim/dark, not black upon starting up. After I leave the TV on for 10 minutes and restarting the TV, it will appear normal.
The warm-up period has progressively taken longer over time. Early on, I did not have to leave the TV on for very long but now I have to leave it on for 40+ minutes before it restarts to normal, bright picture?
Thank you
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
TWP could be a cold solder joint or a failing component. Remove the back cover (unplug your TV of course) and check the boards for any obvious damage (don’t touch anything just yet. Capacitors may still be charged and could zap you). Check for anything that might look “odd”. You can always post images with your QUESTION for clarification. Measure the output voltage from the power board to the backlight LED’s when you just start up your TV and then measure it again when it is warmed up and the picture is showing. See if there is a variance. The other issue could be that backlight itself but check the voltages first.
Bilder zu einer vorhandenen Frage hinzufügen
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
TWP wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 292
