Zum Hauptinhalt wechseln
Modell A1136 mit 30, 60, oder 80 GB Festplatte / Front aus schwarzem oder weißem Kunststoff.
798 Fragen Alle anzeigen
iPod Video not connecting to any computer. Not even old ones.
My iPod will not connect to a computer. It will charge but I don’t here the device insert sound and it will not show up. It is not my computer because a iPod nano will work and I connected to a Windows 7 laptop and got the same result result. I tried to reinstall iTunes but that didn’t help. The 30 pin connector makes a high pitched sound when I plug it in so the connector may be bad.
Ist dies eine gute Frage?
Bewertung 0
7 Kommentare:
@fpfp have you cleaned the connector with a few drops of isopropyl alcohol and a few puffs of compressed air? Have you taken a close look at it to see if the pins are bend/broken? Have you tried a new/different cable?
von
@oldturkey03 I tried that but it didn't help.
von
@fpfp does your iPod work as it should (with the exception of not being recognized)?
von
@oldturkey03 It does turn on but it has a code so I can't do anything with it.
von
@fpfp what kind of code?
von
2 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
1 Antwort
@fpfp yes that makes sense. your iPod will not connect for as long as it has the passcode. It will charge but nothing else. It will not get recognized.
War diese Antwort hilfreich?
Bewertung 0
4 Kommentare:
But when I but it in disk mode, it still does not get recognized and in this video https://www.youtube.com/watch?v=z9MQnadY..., the iPod is locked but still connects.
von
Did you see in those instructions that you need to put your iPod in disk mode? Anyhow I don't think that this is a dock connector issue or a cable issue. This seems more of a software/firmware issue and a passcode issue. Take a look on here and see if that gives you any results How do I unlock my iPod Classic?
von
@oldturkey03 The form says to connect to a computer but I can't.
And I think it is a hardware issue because even apple says to connect to a computer, that even in disk mode it won't connect, and that the iPod looks like it has been dropped at some point.
von
@fpfp going to be very different since you cannot access the iPod. you can of course remove the drive and use a USB-ZiF connector to format the drive and remove all the old files. Then reinstall the firmware and use it then.
von
Antwort hinzufügen
fover wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 161
