Zum Hauptinhalt wechseln
Repair and disassembly guides for GE Microwave ovens.
20 Fragen Alle anzeigen
Stopped microwaving no heat just a loud buzz, sounds like it’s working
I have a GE 2004 Microwave Profile series
MODEL NO. SCA1001HSS 01
LOUISVILLE, KY. 40225
www.GEAppliances.com
MADE IN KOREA
SERIAL NO. GG 902793K
And it stopped microwaving no heat just a loud buzz and sounds like it’s working but no heat? Any reset options before I throw it in the dump?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi,
Check that the two door switches are operating OK and that they’re not loose, faulty or perhaps the door actuating latch is not operating them fully etc.
GE Microwave Interlock Switch - WB24X10047
GE Switch Monitor Interlock - WB24X25397
These switches control the power to the magnetron circuit which heats the food. They are also a safety mechanism that prevents harmful radiation escaping from the oven if the door is opened whilst it is operating by stopping the magnetron circuit from operating
Here’s the service manual for the microwave (I think). On p.51-52 it details how to test the switches and the interlock circuit.
The parts supplier linked above is only to show the switches, their location (click on the switch link) and their possible cost. If a switch is faulty and needs to be replaced, there are other suppliers online that may suit you better. Search online using the manufacturer’s part number only to get results.
If it is not the switches then the schematic on p.57 will help to find out what’s wrong.
Here’s a link that in general details how to test microwave ovens that may also help.
Be safety aware when working on microwave ovens. The HV capacitor can store >6000V DC for months even if the power has been disconnected for this length of time. This amount of voltage can seriously injure you. The HV capacitor needs to be correctly discharged as soon as it is accessible after the oven’s cover has been removed and before doing any further work inside the oven. If you don’t know what you’re doing then don’t do it! Contact a reputable, professional, appliance repair service and ask for a quote.
Activates and deactivates the microwave when the door is opened or closed. Bild
Produkt
$39.99
Ensures the microwave's door latch position is correctly communicated to the control board. Bild
Produkt
$21.99
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
T S wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 49
