Zum Hauptinhalt wechseln
Self-priming automatic electric pumps with helical gears, produced by Marco.
28 Fragen Alle anzeigen
UP12/E-LOBR for ATF oil coolig system?
Hello,
I,ve question is good option to built ATF oil cooling system for cooling electric motor with this pomp ? how long can this pomp work, and can i control flow parameter by the SCS or by simple valve ?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Hi @bedkowski ,
Perhaps @teof knows. You may have to wait for a response as this is a worldwide forum and different time zones means that there may be a delay before getting a reply. Hopefully not more than a day or two.
Moderator.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Dear @bedkowski, please write to export@marco.it for an analysis of your requirements.
Choosing the right pump is a matter of knowing the required flow, pressure and working cycles and our commercial department can help you with that!
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Bartek wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 32
