Zum Hauptinhalt wechseln
Das März 2015 Update von Apples 11" MacBook Air enthält Intel Core i5 und i7 Prozessoren der 5. Generation, was die Leistung und die Akkulaufzeit etwas verbessert.
141 Fragen Alle anzeigen
Fully charged battery needs power cord to wake from sleep
New battery in Mac Air 2015 11”. After going into nap mode, the Mac needs power to start up, but then I can immediately unplug and the battery is charged at the % where I left it. If it never naps, the battery works fine without the power cord.
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Bilder zu einer vorhandenen Frage hinzufügen
von
Not looking for a bot or to feed an app
von
No bot here ;-} And you don't need to buy the app the free use version is all you need for us to get a better idea what's happing.
jcdkjpvopvsic Oops! The robot in me has spoken!
von
ok I've added the image
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
mmm… This is not a new battery! It’s been sitting on a shelf since 2015?? Or is this your original battery??
Sadly, batteries wear out just sitting on a shelf or even inside of a system which is always plugged in to power.
So is the information here from the wrong battery or is SMC messed up. Let’s carefully disconnect the battery and with nothing plugged in press and hold the power button for a good 15 secs to fully discharge the logic board. Now carefully plug in the MagSafe leaving the battery disconnected. Your system should start wait till you get to your desktop and anything that’s auto loaded. Once everything has finished shut down your system and now reconnect the battery. Now this time restart your system, let it run for a good 5 minutes with the MagSafe connected and then take a fresh snapshot posted it here for us to see. Let’s see if things changed.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
This is a battery I purchased on eBay and installed a week ago. My OEM battery was shutting down at 45%. When I get a chance to take the tiny screws out again, I'll follow your directions. Thanks!
von
Antwort hinzufügen
Ryan Buckner wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 221
