Zum Hauptinhalt wechseln
A1418 | EMC 2889 | Ende 2015 | 1,6 GHz Dual-Core Intel Core i5 oder 2,8 GHz Quad-Core Intel Core i5. Erscheinungsdatum 13. Oktober 2015.
LCD Inverter Power Backlight Cable
Hi, there. Wondering what’s wrong with this top LCD light (please refer to attachment)? As it won’t on when iMac is turn on, the other 3 LCD lights are OK. Is it LCD Inverter Power Backlight Cable is faulty? Thanks in advance.
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
Thanks, Dan. I thought the image was uploaded together with the post.
von
Einen Kommentar hinzufügen
1 Antwort
Reconnect the display making sure you properly seat the connections. Use some painters tape to hold the display. If you get an image tale a picture and post it. If you don’t plug in an external display does it show your desktop? If you can’t do that take a flashlight pressed on the display in a dimly lit room you should see a faint image of your desktop and/or do you see a slight glow from the display?
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Kenny Sim wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 30
Insgesamt: 332
