Zum Hauptinhalt wechseln
The CFS-204 is a 90's style analog AM/FM radio and cassette tape player. It can be powered by either six C-cell batteries or A/C power from a standard wall outlet.
6 Fragen Alle anzeigen
Broadcast fuzzy when light switched on
Whenever I switched on the ceiling LED light the radio broadcast became fuzzy with static interference but not so when switched off the light. And this only happened with that one particular light but not with other similar lights in the house . I tried to disconnect the earth wire but it didn't help. I also tried replacing it with another unit of similar type but problem persisted.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
A lot of cheap LED bulbs do this, so you probably put a bulb in that caused the same problem. Radios and cheap LED bulbs do not mix, ever.
You need to look for more expensive bulbs like GE or Feit Electric, especially with a radio.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
thanks Nick. will try this solution.
von
Hi
Did you change the LED driver (aka LED transformer) or only the LED light?
If only the LED light then most likely the problem is with the driver.
The driver is what converts the AC input to a DC output to power the LED light.
Bewertung 0
1 Kommentar:
I did change the driver as well but it did not fix the problem.
von
Antwort hinzufügen
alexee1959 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 57
