Zum Hauptinhalt wechseln
Modell A1136 mit 30, 60, oder 80 GB Festplatte / Front aus schwarzem oder weißem Kunststoff.
798 Fragen Alle anzeigen
Dead battery needing manually charged
Does anyone know how to charge a dead lithium battery with another battery as I have a iPod that has a severely undervolting problem and I need to manually put charge into it
Any known methods
Any help will be greatly appreciated
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The only method would be to wire positive to positive and negative to negative of both batteries. In theory 2 working batteries should balance their power until it gets even, but if you have one dead battery it may not work. However, unless you know for sure the dead battery is not internally shorted or deteriorated, I would avoid playing with lithium batteries, as they have the bad habit to catch fire when things go wrong.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks for the advise
Il avoid doing it and buy a new one
Thanks! :D
von
Antwort hinzufügen
HelloMacOS wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 33
