Samsung WA52M7750AW Top Loader Buttons Not Working
Hello, hoping someone have direct me on the right path. As the title says, Samsung WA52M7750AW top loader. The washer runs fine, but the select buttons, temp, spin, soil, pre load, extra rinse, etc, don't work. You can't change the selection. Power and start/pause, door lock all seem to work just fine
Would issue be the touch sensor assembly or control board or main board? I'm leaning on the touch sensor assembly?
Ist dies eine gute Frage?
7 Kommentare
Are the buttons that you're talking about regular buttons or touch buttons?
von Andrew S
Thanks Andrew. To me there are touch buttons. Unlike the Power and Start/Pause.
von NotDeaf
@notdeaf I think you may have corrosion or other problems on the circuit board that the touch buttons are on. I would recommend disassembling the washing machine and taking a look at the touch sensor board. If you can't find the fault, you can then upload a picture of both sides of rhe touch sensor circuit board. Bilder zu einer vorhandenen Frage hinzufügen
von Andrew S
Good points. I opened it once. Wasn't too sure on how to remove the board from the display. But checked and rechecked the wires and connections, thinking the same, a bad connection, lose wire. Back together and no change, the issue is still there.
I'll take any pointers on removing it from the display.
von NotDeaf
I have the same issue. I have tried the touch sensor and control boards. washer boot up and seems fine. It does have a 56 in the display. I could not find an explanation of this. All touch buttons and the dial are unresponsive. Child lock indicator is not lit. Any ideas
von Jeff Quinton
2 weitere Kommentare anzeigen
