How do I repair the window in the front driver door
How do I repair window in front driver side?
Ist dies eine gute Frage?
You may use WD-40 lube spray. I had to pull my window up and down as much as possible! Then I attached the straw that comes with the WD-40.
Then I sprayed the tracks and other moving parts heaver than usual. Meanwhile I kept moving it up and down until it was free.
Later it successfully began to inch it up. Then I pulled it up and down until it was as new!
It is good to apply WD-40 often as a preventative!
Best wishes!
War diese Antwort hilfreich?
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 27
Hi,
What year is the vehicle?
von jayeff
Also, what kind of repair are you asking about? Please be specific
von brandon k
