Zum Hauptinhalt wechseln
Reparaturanleitungen und Wartungshandbücher für das nasale CPAP-Gerät Respironics REMstar Choice.
Can pressure setting be changed on Remstar Choice LS
I have this older machine. I need to have the Pressure increased. Is this something I can do? Or does it need to be taken somewhere??
Thanks,
John Daniels
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
You need a new sleep study to determine what pressure level you need and they can adjust the level on the sim chip.
Sorry, I haven't checked mine out to see is you can do it yourself. But a new study will take care of the problem and tell you if you have a bigger problem than before.
von Teilen
Yes you can change your pressure. I would love to buy one of these CPAP’s if anyone wants to sell!!!!
von Teilen
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Jj Daniels you really should get those pressure properly adjust by someone in the BioMed field or rep for this device. Speak with your healthcare provider about that.
For educational purpose, there should be a small door on the bottom right. If you remove that, there should be a slot that says "Pressure" You would need a screwdriver to adjust it. There are no preset pressures and you would need a manometer to get the proper pressures. Again, have your healthcare provider assist you with that.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thank you! I will take it to my provider. I would not trust myself to mess around with that stuff!
von Teilen
I have been looking for this Respironics Remstar CPAP’s for several years and would love to buy one!!! 865-850-5566
von Teilen
Antwort hinzufügen
Jj Daniels wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 608
