Zum Hauptinhalt wechseln
Es gibt so viel, was wir tun könnten – wenn wir nur wüssten, wie. Hier sammeln wir Tutorials zu speziellen Techniken, die man bei bestimmten Reparaturen braucht.
489 Fragen Alle anzeigen
How can I easily remove the bits from a 26-bit kit?
If you're anything like me, your fingers aren't needle-nosed pliers. I struggled to remove the tightly-packed bits until I wrapped a rubber band around it and then easily pulled it out. Now whenever I open the kit up, I make sure to have a rubber band nearby so I can quickly and easily get to the bit I need.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
Asked and answered myself. Mainly here in hopes someone else might benefit from the little tip.
von
aaronmiller, it's really not a repair related question ;-) but most certainly a great idea. I think you should take a couple of pictures and create a guide to have it posted on ifixit. http://www.ifixit.com/Guide/new I think that would be very helpful and a neat little guide to have.
Split your original question. Create one true question, and post your tip as an answer. You can even accept your own answer....:-)
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Thanks for the advice oldturkey03 :D
Here's that: iFixit 26 Bit Driver Kit Technique for Removing Bits
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks Jamy, I tried this...handy when you don't have a rubber band around, but with a rubber band, it's even easier.
von
I always put the handle over the bit I want to remove, pull outwards and then upwards, remove the bit from the handle, turn it around, put it back in, and presto :)
Bewertung 0
Antwort hinzufügen
aaronmiller wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 19
Letzte 30 Tage: 36
Insgesamt: 1,178
