Restarts every 3 minutes because of thermalmonitord
Iphone se 2
https://zhidao.baidu.com/question/336459...
Thanks to Chris Stables answer, successfully fixed
Repair process
Ist dies eine gute Frage?
6 Kommentare
Hello. What this Chinese guy did in this video is real? he tested the flex cable without entirely removing and installing it first. How did he do that? I am an amateur. I bought a damaged iPhone SE to change the piece with an original one , but I noticed that if I had bought a new piece it would have a sticky tape to fix inside the vessel of the phone and if I do just removing from the other iPhone SE , I wouldn't have the tape , can I do it with another thing or without any tape at all? THXS
von Jesse henrique
@imicrosoldering could answer for me please?
von Jesse henrique
@jessehenrique You can use some double sided tape if the charging port assembly has none left after removal.
von Chris Stables
Thank you! I am confused about the 71 part of the guide iPhone SE 2020 Lightning Connector Einheit tauschen I really didn't get what to do. It is confusing the converter antenna cable and the small adhesive patch. I would like to know if I can open my iPhone with the conventional way (a suction) and heat because three months before this problem , my iPhone had a battery replacement in a AASP and they do something to make it dust and waterproof again , what is that and how can I open it properly knowing this?
von Jesse henrique
@imicrosoldering
von Jesse henrique
1 weiteren Kommentar anzeigen
