Zum Hauptinhalt wechseln
Reparaturanleitungen und Informationen zum Google Pixel 4a 5G. Erschienen am 29. Oktober 2020. Modellnummer: G025E
33 Fragen Alle anzeigen
Front and Rear cameras broken. Fixable?
I am looking to purchase a used Pixel 4a 5g from ebay but it claims that the cameras have bad quality or does not open. What I would like to know is can this be fixed by simply replacing the cameras or is this a motherboard issue is some kind? I did some reading and claims that it is a defect but I can't 100% confirm this. Any thoughts?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
You could try a hard reset which will wipe all data on the phone to hard reset the Google pixel 4a Press and hold the Power button. While you hold Power, press the Volume Up button and let go of both buttons quickly. Android Recovery options should be displayed. With the volume buttons, scroll to "Wipe data/factory reset" and press the Power button. If that doesn’t work replace the cameras it is very unlikely to be a motherboard issue
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I ended up purchasing a Pixel 4a 5G that has a line on the screen but is otherwise fully functional. Actually I managed to get the line to disappear by simply pressing in the bottom right area. Eventually I am planning to purchase a replacement screen and considering that parts are now available on ifixit that temptation is higher.
von
Antwort hinzufügen
Dudefoxlive wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 50
