Zum Hauptinhalt wechseln
An external optical drive by Apple, essentially a rebranding of the MacBook Air SuperDrive.
33 Fragen Alle anzeigen
Can I open an Apple USB superdrive?
Hi
I have an Apple USB Superdrive that has a CD stuck in it. None of the usual methods of ejecting the CD work, the drive isn't even recognised by the system. The drive appears to be working because when I use the terminal command to eject it does respond but the CD doesn't pop out. The CD is worth much more to me than the drive itself, I'd be happy to write it off if it means I can get the CD out without damage.
On the underside of the drive there's a large rubber circular closure like the ones on the Mac Mini, but there's no way I can move it. I have one of those little rubber grippers that you remove LED bulbs with, but no spudger (yet). Is this the way to open the drive if I have the right tools?
TIA.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Follow this guide to open it Apple USB SuperDrive Optical Drive Replacement Should be able to pop off the cover place after Step 4
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thank you so much, Dan, that looks good.
Much appreciated.
von
Antwort hinzufügen
Pauline Caldwell wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 33
