Zum Hauptinhalt wechseln
Modell A1502 / 2,4, 2,6, oder 2,8 GHz Dual-Core Intel Prozessor / Erschienen im Oktober 2013
552 Fragen Alle anzeigen
How can I get this ribbon cable to connect?
I was swapping top cases on my MacBook pro when I damaged part of the keyboard connector trying to take the ribbon cable out. I tried to put the keyboard ribbon cable back into the connector in my new top case. But it just wouldn't fit. I could start to see the layers on the ribbon cable spread apart, making it harder to put back in. At that point, I stopped, not trying to make it worse.
Is there any way at this point that I can put the ribbon cable back in so that all the keys work? Or am I better off just going to a repair shop and see if they can repair it. Is it even repairable at all?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
on photo 2 the bottom of the connector is a plastic tab, lift it up, put the ribbon in and close
War diese Antwort hilfreich?
Bewertung 2
5 Kommentare:
I thought that too, that's why the connector is slightly broken. I tried to lift it up but the plastic is so brittle that it just breaks off. By the way, all the other connectors just slide in, no tabs or anything.
von
@Tom Dilli your lifting the wrong side thats why its breaking
von
@Tom Dilli - It looks broken to me! Time to replace at least the latch piece if you can. Here's the needed part Keyboard Connector (30-pin)
But if you need to replace the full connector its not easy! You'll need a good soldering iron or a hot air station. Its very easy to damage the logic board lifting the copper pads.
von
@tech_ni sorry I totally misread your reply thanks!
von
@tech_ni this is another follow-up to that other follow-up. I just wanted to thank you so much for your great instructions, If not for you I would have just taken it to the apple store and gotten a really expensive repair. You are a life saver!!!
von
Antwort hinzufügen
Tom Dilli wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 176
