Zum Hauptinhalt wechseln
My VCR is flashing CST.in
My VCR turns off after about 3 seconds, and then starts flashing the CST.in light. I don't visibly see anything caught inside, even after taking off the case. It does take tapes but due to it shutting off and not turning back on, I have to open the case and fish it back out. I have found people online with similar issues, but none of them helped me.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
The tray that the tape sits in and moves it may be out of sync or position.
Unplug it, put your fingers in like a cassette sort of & try to push it back in, then pull it back to the front of VCR.
This may do the trick.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Thanks for the suggestion, but it didn't work. There is a belt which makes the tray eject, and whenever the unit gets plugged in, it rotates that belt and causes the tray to jam, and not accept tapes. If I go into the VCR and rotate the belt in the other direction, it frees up the tray and then I can do that, but still no dice unfortunately.
von
Antwort hinzufügen
Josh Siffner wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 24
Letzte 30 Tage: 118
Insgesamt: 2,905
