Zum Hauptinhalt wechseln
Repair guides and support for computer monitors produced by Samsung.
20 Fragen Alle anzeigen
Samsung 204BW Display Capacitors
What capacitors do I need for a Samsung 204BW display? And do my capacitors look like they need replacing? Thanks in advance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
12 Kommentare
What is the problem with the display?
von
I have to press the power button multiple times. Before screen displays. Seen from other monitor fixes it's most likely the capacitors.
von
@clatyn Can you take the back off the monitor and upload pictures of the circuit boards? Bilder zu einer vorhandenen Frage hinzufügen
von
Currently using the monitor. Can you answer original question?
von
@clatyn Sorry, I don't have that monitor, therefore, I don't know what capacitors are used on its power board, which is information I would need to recommend replacement capacitors.
von
7 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
@clatyn I am linking you to RS Components UK-I believe they offer free shipping
470 uF 25V Capacitor - Order 5
1000 uF 25V Capacitor - Order 5
The total should come out to about £6 excluding VAT
War diese Antwort hilfreich?
Bewertung 2
Hilfreichste Antwort
The size is printed on the capacitors themselves. Top left top is domed, far right looks similar and has leaked on top and bottom one looks like it might of swelled too.
Bewertung 2
@clatyn
It may save time and most probably cost just the same to get the 204BW capacitor replacement kit. Depending on your location as regards shipping etc. of course.
Update (07/05/2022)
Hi @clatyn
OK
Here's a supplier that actually states part of the values (not the voltage rating only the capacitance value) and number of each of the capacitors required except the 400V-450V ones (capacitance value and number required unspecified - see note regarding these.)
You may have to open it up to find what you want and then try this supplier to get them. The capacitance and voltage rating options are on the left side of the page.
Bewertung 1
1 Kommentar:
Unfortunately I'm based in UK. So the shipping is actually more expensive than the product. 😥
von
Antwort hinzufügen
Clatyn Janes wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 150
