Zum Hauptinhalt wechseln
Veröffentlicht am 21. September 2018. Modelle A1921, A2101, A2102, A2104. Erhältlich als GSM oder CDMA / eSIM oder dual-SIM / 64, 256 oder 512 GB / Silber, Gold oder Space Grau (Ausgesprochen "iPhone 10s.")
20 Fragen Alle anzeigen
How to remove the Passcode with out losing data?
I’m the owner of the device and the Apple ID being used on the device I just forgot the passcode from it and it’s also currently with the “iPhone disable connect to iTunes ”sign from trying every number I could remember lol 🤦🏻‍♂️
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
use 3utool and reflash with retaining user data
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
The device is in disable mode would I have to get the device into dfu mode for the device to connect to 37tools and follow your suggestions?
von
@taco18 dfu or recovery mode
von
@tech_ni thanks for your help I tried following the steps to get the device in DFU mode, then flash process maintaining user's data I still find myself in need of a passcode even on the attempt to retrieve user's data and once I use a passcode I believe it's correct the phone gets into an iPhone unavailable try again in some minutes. If there's anything you know I should do to get rid of the passcode please help once again
von
Put it into dfu. Recovery resets after 15 minutes turning the phone on losing the connection to pc, dfu doesn’t.
Bewertung 1
Waimond michae
Update (11/14/24)
Sign out apple
Bewertung 0
1 Kommentar:
Sign out apple
von
Antwort hinzufügen
Taco wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 144
