Zum Hauptinhalt wechseln
Diese Anleitung hilft dir dabei, Probleme mit deinen PowerBeats3 Wireless Earphones zu beheben.
volume control button cover came off
Hello
With my earbuds the buttons of the volume control came off. I believe they still work just fine. The glue or adhesive just gave up. What can i use to glue them back down, and is there a preferred way of applying said adhesive?
Thanks!!
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi
From what you have said I would use the TESA tape that ifixit sells and cut it to the shape you need
If you can provide some photos I can better help you however this may not be necessary
Here’s a guide in how to add photos
https://www.ifixit.com/Guide/Adding+imag...
Also here’s a excellent video on how to repair the volume buttons on any beats in ears
https://m.youtube.com/watch?v=nXSjQzwTDM...
Hopefully this helps
Any questions please ask
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
I have added a photo!
von
@stinder
Thanks for the photo
You could use tesa tape or b7000 glue like in the video
It shouldn’t really matter as ether one will do a good job
Just follow along with the video and your beats will be good as new!
If you need any more help just let me know
von
@stinder, when your volume keys cover came off, did the cable on the bottom also "tear?" I have a similar issue, but it may be more severe and gluing the cover back on will not solve my issue with the bottom cable assembly being torn.
von
Antwort hinzufügen
Bryan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 36
Insgesamt: 1,549
