Zum Hauptinhalt wechseln
Das TexSpray RTX2000pi ist ein Textursprühgerät von Graco zum Auftragen von Spritzputz sowie zur Erzeugung von Strukturen wie Orange-Peel, Splatter, Knockdown und Popcorn auf Wänden und Decken. Seriennummern 17H573 (RTX2000pi), 17H574 (RTX2000pi Rental) und 17K301 (RTX2000pi RentalHD).
How do you replace the pump hose inside the unit?
How to replace the pump hose inside the unit ?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
The unit uses a peristaltic pump, with two motor driven rollers alternately squeezing the hose and pushing material forward. You will need a #288623 replacement pump hose. This is for an RTX2000pi. The 1400 pi and 2500pi are very similar.
  • Turn off the sprayer and wait 7 seconds for power to dissipate
  • Unplug the sprayer
  • Back off the material feed control to minimum so the tension on the hose is less.
  • Relieve the air pressure in the air hose with the priming valve.
  • Disconnect all the hoses from the front of the unit.
  • Remove the material hopper.
  • Remove the pump access door on the left side of the unit. It's the side opposite the switch side
    • You will need a 3/8" nut driver to undo the bolt.
    • You can rotate it up out of the way and then tighten the knob that also holds the plate so it stays up
  • Remove the knob right next to the place where the hopper connects to the inlet port . This holds on the hose plate.
  • Lift off the hose plate.
  • You can slide the pump hose to the left
  • Squeeze the pump hose together and remove it from the unit.
  • Install the new hose (the clear part toward the rollers).
  • Slide it to the right so the grooves on the hose couplings are held by the front plate of the unit.
  • Replace the hose plate and reassemble the remainder of the unit in reverse order.
Here's a link to a video from Graco of the whole process.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Can this hose affect air pressure
von
Antwort hinzufügen
Kenneth A Rolle wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 28
Insgesamt: 855
