Zum Hauptinhalt wechseln
Das im November 2020 erschienene 13" MacBook Air verfügt über Apples Arm-basierten M1-SoC mit einer 8-Kern-CPU und bis zu einer 8-Kern-GPU. (Modell A2337 / EMC 3598 mit zwei Thunderbolt 3-Anschlüssen)
102 Fragen Alle anzeigen
I did a bad thing when trying to fix my track pad
Hi! I am determined to finish this repair myself! (Mostly because it suddenly dawned on me that I could have just bought a fancy external mousepad by now) Anyways, I have watched this video https://www.youtube.com/watch?v=ieZh6yww... a half dozen times (Bless Binh and his Ginea Pig) And of course when I got the parts I got all spitfire like I could just talk to computers like Binh and just went at it and foolishly pulled out the connection part that is mounted to the left just above the center screw with the old cable. Stoooooooooopid. What do I do? There are two broken pins. :( Do I get to add a soldering knife to my tool kit? I promise to be patient. I should have been patient and watched the video and followed along. Learning is expensive. Help me please? please. thank you!
Ist dies eine gute Frage?
Bewertung 3
2 Kommentare
So I did buy a new track pad with the cable. It was when I was taking out the old cable I accidentally pulled that connection. So that connection is for that microphone? I’m totally cool without a microphone!
So I did the Install of the new parts minus that one connection but now the keyboard doesn’t work. It worked before the repair :/ gonna have to hook up a keyboard to see what is happening.
Thank you for your help!
von
@mmmara - so which answer solved the question? Accept the answer that fixed it
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi
I can help you finish your repair!
If you can upload some photos of your broken connector will be able to give you some advice on how to fix it
Here’s a guide on how to add photos
Bilder zu einer vorhandenen Frage hinzufügen
If it is damaged you will most likely need to solder on a new one which I can help you along with over the answers forum
Hopefully this helps
Any questions please ask
War diese Antwort hilfreich?
Bewertung 2
5 Kommentare:
Hello! I updated my question with photos let me know if I can take better ones! Thank you so much for your answer!
von
@mmmara
Thanks!
Il have a look:-)
von
@mmmara
I have had a look and you will probably have to replace your trackpad
Or you could find one that isn’t fully working and desolder the connector from the other side of the board
But it’s entirely up to you
No matter what choice you make I am here if you need any help:-)
von
Hello, where i can get daughterboard for trackpad, keyboard and backlight keyboard, this part common problem if Macbook got watter damage.
von
@malta32
Is it the small board on the bottom of the track pad that you are talking about?
von
Well, you are quite lucky!
It's just the Microphone,
Alliterative:
If that's a huge problem you need to buy a new trackpad,
Part: MacBook Air 13" (A2337, Late 2020) Trackpad
MacBook Air 13" (A2337, Late 2020) Trackpad Bild
Produkt
$79.99
Bewertung 1
Antwort hinzufügen
Mara wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 9
Insgesamt: 156
