Zum Hauptinhalt wechseln
This 'SHIELD Pro' Android TV console by Nvidia is a slightly enhanced version to the 'SHIELD' console released for sale on May 28th, 2015. It contains mostly the same internal hardwares as the original 'SHIELD' console with a much higher storage capacity of 500GB as compared to the 16GB of the standard 'SHIELD' device. The model number for the device is P2571.
What screwdriver to open tube version
What tool to open tube Nvidia Shield tv
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare
Hi @superman6969,
What is the model number or full model name of the device as there are different "Shield" models?
von
Nvidia Shield Android Tv 8gb 4k HDR Media Streamer.
Model # 945-13430-2500-000
von
@superman6969
Can't find info on opening it, but if there are any screw heads showing post an image of it back here (also try to measure the screwhead for size - diameter in mm?) and maybe it can be identified as to type and size etc.
here's how on ifixit Bilder zu einer vorhandenen Frage hinzufügen
If none showing, maybe it has a"welded" plastic seam and it has to be cracked open
von
It's a really really small torx screw. Hope I can find one. Want to take apart to see if it's full of dust cause it gets hot now and when I try to watch 4k it shuts Kodi down, which it never did before, but..... just as I'm writing this it won't even turn on, not cool
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @superman6969
Ifixit sells a range of smaller size torx drivers
Here's an image showing what the sizes are in imperial and metric that may make it easier to know what size you need.
(click on image to enlarge)
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Bob barker wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 428
