Newbie Question - LCD Not Longer Working After USB-C Replacement -
Hi,
First I’m going to say I’m quite the newbie to this. I’m going to start from the start here.
I bought a faulty Switch Lite from eBay. Reportedly needing charging port replaced. I replaced a fault USB-C port on the Switch Lite. It worked but would only charge on one side. I took this to mean the hidden pins maybe didn’t make a good connection. But also I found out once it booted up that the right stick was needing replaced also. Took this as a good excuse to try and fix my the USB-C issue.
Re-placed the port to see if that would help. Installed the new stick. Put it back together. However I get no screen, only sound. And I don’t think the Switch Lite boots up unless it’s plugged into power. My Amp Meter is showing around 0.6-0.7 amps when it’s on.
Does anyone know what I can do to check this out? I’ve tried reseating all the cables and cleaning them incase I maybe got them dirty. But nothing seems to help. I’ve got a multimeter. Is there any readings of components I should check at all?
As I said, I’m quite the newb to such repairs, so I kind of need it explained in layman’s terms also haha.
Thanks for any and all help. It’s greatly appreciated.
Ist dies eine gute Frage?
so it turned on before you tried to repair the port ? reading 1 side can be bad port or m92t36 in some cases
von daniel
