Zum Hauptinhalt wechseln
Modell A1418 / Mitte 2014 / 1,4, 2,7 & 2,9 GHz Core i5 oder 3,1 GHz Core i7 Prozessor
50 Fragen Alle anzeigen
White stains on motherboard
I have an iMac that is not powering on anymore. After removing the display to inspect the interior, I noticed white spots in a certain area on the motherboard. I'm not sure if this is relevant to the malfunction as I've seen this on working boards as well. It's unlikely to be liquid damage as the screen seals the device pretty well.
What am I looking at here?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi
That could e be a couple things
1.it could be corrosion which could be related to it not turning on
2.it could be a type of grease that is used for keeping moisture out but do don’t remember ever really seeing it on a iMac
I would try cleaning it away with some isopropyl alcohol and some cotton buds/Qtips
Hopefully this helps
Any questions please ask
War diese Antwort hilfreich?
Bewertung 0
6 Kommentare:
Huh, it's really curious that the two biggest spots have a very distinct semicircle shape. Is there any other component mounted right above the board there?
von
@dadibrokeit
Yeah strange isn’t it
Apple used to use this grease powder stuff that looked a lot like on the photos but I remember it being used in the ram slots
From the photo it looks like where the cpu cooler screws on because the screw stand off things look similar
von
The semi-circles match the outline of the capacitors on the other side.
I'm guessing the system is used within a humid area or climate near the ocean as this looks like salt deposits.
von
@danj
That’s probably it!
von
@danj That's wildly interesting Dan as the iMac was sitting 2 rooms away from a pool. Any explanation as to why these salt deposits would form around a cap? Something to do with amount of heat from capacitors?
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
Sam wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 22
Insgesamt: 377
