Zum Hauptinhalt wechseln
Reparaturanleitungen, Demontage- und Fehlerdiagnose-Informationen für die erste Generation des Apple iPad mit 3G-Konnektivität, verfügbar mit 16, 32 oder 64 GB Speicherkapazität. Veröffentlicht im April 2010. Identifizierbar durch die Modellnummer A1337.
Where Can I Buy A Replacement Battery?
Hello,
I own a Apple iPad 1st Generation 64GB 3G/GPS or A1337 of which when I plug in and attempt to turn on boot-loops. When I attempt to put it into DFU mode and plug it into a PC or Mac it will either immediately turn off (the iPad only boot-loops when plugged in) or if I used a adapter that allowed it to be plugged into power and the Mac or PC at the same time, it would not show up on iTunes. I'm 95% sure that it is a battery problem meaning I need a replacement battery. I looked on the iFixIt Store and the oldest iPad they supply parts for (let alone battery replacements) is the iPad 2 and anywhere else I could find that supplied battery replacements for the iPad 1st gen were on sketchy websites or hosted by sketchy sellers on places like EBay and AliExpress (even Wish at one point)
If anyone can help by sending a link or showing me a place to find a replacement battery I would be really grateful.
Thank you,
-Jenson
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Your right about it being a battery issue!
Part: iPad Battery
Guide: iPad 3G Akku tauschen
Replace a 6600 mAh battery compatible with iPad 1st Gen A1219 and A1337 models Wi-Fi and 3G. Battery model #A1315. 3.7 Volts (V). Part #616-0448. Bild
Produkt
iPad Battery
$38.99
War diese Antwort hilfreich?
Bewertung 0
If you’re in the uk look for seller like Replace Base or repair outlet. Trusted sellers I use all the time.
Bewertung 0
Antwort hinzufügen
Jenson Cutting wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 19
Insgesamt: 298
