Zum Hauptinhalt wechseln
A2116 / 2019 / 3,6 GHz Quad-Core i3, 3,0 GHz 6-Core i5 oder 3,2 GHz 6-Core i7 Prozessor. Veröffentlicht am 19. März 2019.
Can I upgrade my 2019 21.5" iMac PCIe/NVMe to p5 Crucial SSD?
Hi, I have 2019 21.5" iMac 3.6GHz (19.2)
I want to upgrade the PCIe/NVM2 blade SSD to 2TB model using a Crucial p5 SSD Is this possible? Or use this Crucial p2 SSD
Also, can I add the memory capacity up to 64GB?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Here's a good source of info on your system 2019 21.5" Core i3 3.6GHz iMac (4K).
This model has a Serial ATA (6 Gb/s) connector for a 2.5" hard drive. If configured with a "Fusion" Drive or an SSD at the initial time of system purchase, it also has a PCIe connector, but this connector is not present if the system only is configured with a hard drive.
So depending on your exact system it may not be populated with the custom Apple PCIe/NVMe blade SSD connection. Sadly you can't use the M2. SSD's made by Crucial as Apples is different. If present, here's the part info iMac Intel 21.5" (Mid 2017-2019, Select Models) Blade SSD Upgrade Bundle and here's the guide to put it in iMac Intel 21,5" Retina 4K Display (2017) Blade SSD austauschen while this is for the 2117 model its the same procedure and uses the same blade SSD drive. Otherwise you'll need to go with the iMac Intel 21.5" Retina 4K Display 2019 Festplatte tauschen using a 2.5" SATA SSD.
Here's the needed RAM kit iMac Intel 21.5" EMC 3195 (2019, 4K Display) Memory Maxxer RAM Upgrade Kit to boost your system to 64GB (60-pin) DDR4 SO-DIMMs - PC4-19200 2400 MHz (for Core i3 system) or PC4-21300 2666 MHz (for Core i5/i7 systems) and here's the guide iMac Intel 21,5" Retina 4K Display 2019 RAM tauschen
Max your iMac Intel 21.5" EMC 3195 (2019, 4K Display) with 64 GB RAM. Upgrade bundle includes all the parts and tools needed to mod your iMac. Bild
Produkt
$529.99
Upgrade your iMac with a new SSD to dramatically speed up your machine. Bild
Produkt
$249.99
iMac Intel 21.5" Retina 4K Display (2017) Blade SSD Bild
Anleitung
Schwierigkeitsgrad:
Mittel
1 - 3 hours
iMac Intel 21.5" Retina 4K Display 2019 Festplatte Bild
Anleitung
Schwierigkeitsgrad:
Mittel
30 minutes - 1 hour
iMac Intel 21.5" Retina 4K Display 2019 RAM Bild
Anleitung
Schwierigkeitsgrad:
Mittel
1 - 3 hours
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Just to make this correct for future folks reading this: yes, you can use an NVMe drive in place of the Apple blade SSD, and have been able to for years as it uses the same Apple proprietary pin out as the MacBook/MacBook Pro SSD for which there has been NVMe to MacBook adapters for quite some time, including the date of the earlier reply that said no you can’t.
von
@infografixatl - First off not all of the systems in this series offer the Blade interface so depending n what the OP bought the blade drive may not be possible.
As far as using a M.2 SSD with an adapter over using an Apple custom blade SSD while one can do it there are issues! First off there are now four different M.2 specs so one needs to be careful which drive you use, then there is the quality of the adapter and how it effects the signal. While day one I’m sure using the correct drive you won’t see any issues, but over time you might get a surprise! And given how much work it is to get to the connector is it worth the risks? I always recommend a pin compatible drive over an adapter in iMacs either an Apple Original driver or using either an OWC or Transcend as being the ones I have seen which are quite good.
I’m only willing to play Russian Roulette with the least amount of bullets or none at all.
von
Antwort hinzufügen
hozifa kanani wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 35
Insgesamt: 1,412
