Hi @mosfella,
Please elaborate on "....the base does not see the phone line". What do you mean by this?
Can you call out and receive calls OK on the handsets?
Is the display on the base station working?
Try resetting the base station and see if this resolves the problem;
To reset the base station:
- Unplug the power supply unit.
- Press and hold the paging key on the base station.
- Plug the power supply unit back in.
- Press and hold the paging key on the base station for another 5 seconds, then release it.
If it now works you will have to re-register thew handsets with the base station again
If there is an info label on the underside of the base station, gently peel it off and check if there is a hidden recessed "5th screw" there that may be holding the case together.
if not it may be that there are clips holding along a seam line (if it has one) and it has to be pried open, but usually if there are screws there won't be.
If you do get it open post some images of the board, especially near where the power connects to it as most likely if the adapter was fried then most likely the power section of the board wouldn't be too good either.
Here's how to add images to your 'question' on ifixit. Bilder zu einer vorhandenen Frage hinzufügen
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
