Zum Hauptinhalt wechseln
Won’t make ice automatically but will if you his test button
My Samsung fridge stopped making ice on its own. Checked for filter issues, water line kinks. If you hit test button it dumps ice into bucket and refills and tone sounds that it’s working. Water dispenses normally
Update (10/18/2022)
RS27T5200SR/AA
Samsung Side by Side 2020
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare
Without knowing the model, we can only guess since Samsung makes quite a few different kinds of refrigerators, but my first thought is that many icemakers have a lever that shuts off the icemaker when the bin fills. I'm thinking there may be an issue of some kind with that lever; I know my son's icemaker shows if you push the lever all the way to the horizontal position, it basically shuts off the icemaker.
von
Any answers on this? Same.. powered down fridge,, Test button produces ice... No ice any other time.. filter is clean...
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi Tracie,
Okay, thanks for the model information; that helps.
The obvious place to start is with Samsung's recommended troubleshooting steps. You've already done some of them, obviously, but please check through their list and let us know if any of their suggestions helps. If not, come back and let us know and we'll figure out what your next step should be.
Ice maker is not working
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
All trouble shooting tips completed. Even reset fridge. Again, still making ice when test is completed but won’t just go through the process automatically.
von
Did you find out why? Mine doing same thing.
von
Same here... can only get the ice cubes/bits by pressing test button
von
After trying all the troubleshooting, I finally brought in a service person and they said the sensors sometimes break, so it wasn't sensing that there was space for more ice but would make it when I manually forced it. They ended up replacing it so I'm not sure if there is a non-replacement fix, unfortunately.
Bewertung 2
1 Kommentar:
Allison, what did they replace? I've had a new icemaker installed but it still won't make ice on its own. I did notice tech didn't replace the mother board on the back of the fridge. Did you get a new board for your fridge? It comes with the icemaker he should've replaced the board. I'll never use them for anything
von
Antwort hinzufügen
Tracie Sanders wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 46
Letzte 30 Tage: 190
Insgesamt: 2,347
