Zum Hauptinhalt wechseln
Zweite Generation des Ford Focus.
Can I remove the hub and wheel bearing together when removing them
Can I remove the hub and wheel bearing together when removing them on front drive side it shows people removing bearings first then hub I'm buying the hub and bearings together and it shows both being put on together I have 2005 focus
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
There is an outter and inner wheel bearing the bearings will sometimes slide off with the hub or rotary, a sometimes they are pressed on the axel or spindle. Usually the outer will side of with the hub or axel, the inner bearing is the one that may be more difficult!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Trina Orrico wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 250
