Zum Hauptinhalt wechseln
Das kleinste iPhone 14 von Apple wurde am 9. September herausgebracht und verfügt über ein 6,1-Zoll-OLED-Display, ein fortschrittliches Dual-Kamerasystem mit 12 MP und eine Frontkamera mit Autofokus. Es ist der Nachfolger des iPhone 13.
4 Fragen Alle anzeigen
Why does my iPhone 14 has a smudge on the display?
My Iphone has a smudge which can be visible mostly on grey screens and also can be seen on screenshots. This is weird, since i can see it in a screenshot i think it has some thing to do with software but I'm not sure.
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
iOS 16.1.1 just released. Maybe you can try updating?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi
It looks like it could be some form of
discolouration between the layers or the display
If it’s still in warranty it might be worth a shot taking it to apple to get it fixed under warranty however if it isn’t available you could replace the display to fix the issue
Here’s the guide for that
iPhone 14 Display tauschen
However if it appears in a screenshot it is a software issue and could be fixed by restoring the phone or waiting for a software update that fixes it
Hopefully this helps
Any questions please ask
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
If it appears in a screenshot than it is probably not a issue for the screen.
von
@thequacker
I mentioned that in a edit :-)
I only realised it was a screen shot after I looked at it several times XD
von
@hellomacos No problem!
von
Let's retrace:
  • If the issue is on your phone display but doesn't appear on a screenshot it is caused by a stain on the display, such as sauce.
  • If the issue appears on the phone display and screenshot it's a common problem caused by LCD damage or discoloration.
If it's the first issue grab paper towels and thoroughly clean off the display. If it's the second issue you have to replace the display screen either at home or at a repair shop. Just make sure your device still has warranty for qualified repair.
Bewertung 1
Antwort hinzufügen
Alon Karaev wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 4
Letzten 7 Tage: 19
Letzten 30 Tage: 86
Insgesamt: 375
