Zum Hauptinhalt wechseln
Das im November 2020 erschienene 13" MacBook Air verfügt über Apples Arm-basierten M1-SoC mit einer 8-Kern-CPU und bis zu einer 8-Kern-GPU. (Modell A2337 / EMC 3598 mit zwei Thunderbolt 3-Anschlüssen)
102 Fragen Alle anzeigen
Screen cracks when opening
Hello. I changed the screen of a macbook and I realized that when I open and close the screen quickly (normaly, like if it's the first time you open your mac), there are no problems. But if I move it gently to reposition the screen higher or lower and therefore go more slowly when I move it, it makes a little creak when I start to move it. I hope I explained myself clearly enough. Any explanations/solutions? Thanks.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi
It might be worth cleaning the hinges with isopropyl alcohol from the inside as there could be debris caught in them
Here’s the guide for getting the display off
MacBook Air 13" (Ende 2020) Display tauschen
I would stay away from lubricants as they could remove the tension/stiffness of the hinges
Also if you go ahead with the isopropyl alcohol make sure to use it with a soft cloth in small amounts as it can get behind the display if you aren’t careful which can cause watermarks on the display behind the glass
Hopefully this helps
Any questions please ask
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Thibaut wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 5
Insgesamt: 69
