Repairing Burnt out Motor (Kitchen Appliance): Burr Coffee Grinder
Hello,
I think I've "burnt out the motor," or whatever the technical term is, on my burr coffee grinder, by plugging it in to a 240v plug.
Is the solution replacing the motor, the wiring, or what? I assume many appliances operate the same when having and issue like this, so any advice from similar kitchen appliances are welcome!
Thank you for your time!
Update (02/02/2023)
I finally opened up the coffee grinder to examine the issue (btw, my grinder is an OXO one that doesn't have a guide yet on fixit.)
I think I found the problem(see images where components have burn damage)..but I have no idea what I'm looking at.
I'm quite keen to fix it. Especially since I emailed OXO for help and they said "just buy a new one."
Ist dies eine gute Frage?
1 Kommentar
@z_ro we actually see this quite often on here :-) Anyhow, like it was mentioned before, you do need to take a look at it. If yours has an internal fuse, you maybe safe. Most of those still blow some parts on the logic boards. Commonly are the resistors and rectifiers. Most of the stuff is repairable but we need to see it. Take some good pictures of your Burr Coffee Grinder (make and model?) and post those with your question. If you can get it apart, go ahead and do so and again post plenty of images so we can assist you further.
To add images, edit your QUESTION and use this guide Bilder zu einer vorhandenen Frage hinzufügen
von oldturkey03
